i got a 33mm pwk 2into 1 carb kit but needs jetting. i really dont wana spend a lot on jets and dont wana headache. its a stock motor fmf pipes and my alt. is arond 650 please help
i used to have two shees with the 2 into 1 carb set up with 33mm i had allot of trouble jetting that carb. i called cascade innovations and they said they had trouble running a 33 also they said they couldnt dial it in right, it just doent flow enough air. they said they had good resluts with a 35 mm so i switched and what an improvement it ran allot better. now im not saying it wont run on a 33 but you have problems fouling plugs because you have to jet it according to your set up ae pipes filter motor mods, and when you do this and the bike is at idle or your just cruzing like at 1/4 throttle too much gas is intering cyclnders and not enough air and therfore the plugs foul. you may have more luck then i had
