gmctruck1976 Posted June 26, 2008 Report Posted June 26, 2008 Ok guys i just got done reading a bunch of these post and im completely lost. Im building, 4 mill with 110 rods, 21cc domes with the 2mill milled for crank, trinity single carb 35m v force 3 reads and fmf fatty. stock port. ill be running 93 oct @32 to 1 mix synthetic elevation aprox. 200ft ave. Humidity runs on ave around 60 to 70 % where do i start, who sell a good jet kit with at least a few different set ups to use. IM not sure what all cam with the new carb. so i cant give info on that right now just looking for a starting point for my build. I do rebuild alright but when it comes to carb set ups im completely lost any help wiould be gratefull Quote
Snopczynski Posted June 26, 2008 Report Posted June 26, 2008 Ok guys i just got done reading a bunch of these post and im completely lost.Im building, 4 mill with 110 rods, 21cc domes with the 2mill milled for crank, trinity single carb 35m v force 3 reads and fmf fatty. stock port. ill be running 93 oct @32 to 1 mix synthetic elevation aprox. 200ft ave. Humidity runs on ave around 60 to 70 % where do i start, who sell a good jet kit with at least a few different set ups to use. IM not sure what all cam with the new carb. so i cant give info on that right now just looking for a starting point for my build. I do rebuild alright but when it comes to carb set ups im completely lost any help wiould be gratefull PWK 35mm= 200 main, eej needle, clip 2nd notch down from the top, 45 pilot jet, air screw 1.5 turns out from all the way in. Hopefully your running a pod filter? Quote
