darren44 Posted June 22, 2008 Report Posted June 22, 2008 (edited) hey, i was just at waynoka and i was having prob. with my bike. it is a 2001 banshee with LC performance drag ported jugs, v-force reed, daul 33mm keihin carbs, clamp on k/n's, +5 timing plate, running a hemi head with 18cc domes, and it as shearer inframe pipes. i could not seem to get the jetting down just right what do yall think i should have in it. Edited June 22, 2008 by darren44 Quote
darren44 Posted June 30, 2008 Author Report Posted June 30, 2008 hey did i put something down wrong, or does no one have anything to say. just needing some help with drag ported jugs. nothing big. does anyone know just a little. just needing a little help jetting. anyone???? thanks Quote
black sunshine Posted July 1, 2008 Report Posted July 1, 2008 IDK anything about 33's but you need to give the kind folks here some more info on your setup. What jets you tried and how it ran, needle type/clip position, temp. and elevation. That may get a few bites for you Quote
Toomey Banshee Posted July 1, 2008 Report Posted July 1, 2008 IDK anything about 33's but you need to give the kind folks here some more info on your setup. What jets you tried and how it ran, needle type/clip position, temp. and elevation. That may get a few bites for you On two of my ported bikes with 33 PWK's we run 170 and 165 mains, 52 pilots, CEL needles, clip 2nd down from the blunt end. In the future list what you're running and the problems you're experiencing. Quote
