Here we have a 99 yamaha banshee with 2004 motor,running on vp race fuel,but can run on high octane pump gas also.Here is a list of the options it has::4mm stroker crank,.60 bore,Heads milled,Ported Cylinders,Boost Bottle,K&N Air Filter Tors Removed,Renthal Handlebars,Clear hoses,Synthetic oil used only,Extended Axle,+2 Swingarm,Lonestar Extended A-arms,Works Tripple Rate Front Shocks,Bumpsticks Rear shock,New Rear tires,(could use some new front tires though)but i will thrw in some rear Gecko sand paddle tires,Maier race plastics,New ASV clutch and brake levers,Steering Stablizer installed,Toomey T-5 Pipes and Silencers,Tether Killswitch,Carbonfiber Reeds and more,asking 2500 call 240-838-4954
why did you not sell this on e bay the 2 times it was listed? deadbeat bidders again? why no 2 nd chance offers to the 2 nd highest bidders? ran it up and got stuck? how can you prove it`s a 4 mil? .60 over? you will have to answer my questions here. you ignored me on e bay.
