omalavet Posted June 17, 2008 Report Posted June 17, 2008 my shee is leaking oil from behind of the fill cap .... i havent do nothing to the shee .... i change the clucht like 2 moth ago .... put a new seal.... but its been two month now what could it be??? it have all the screws in... Quote
bronco91shee Posted June 18, 2008 Report Posted June 18, 2008 MABYE THE SEAL HAS BEEN DEFORMED AND DOESNT SEAL CORRENTLY. AMBYE SUMTHING GOT IN THERE WHILE YOU WERE INSTALLING IT AND NOW IT IS LEAKING? ARE THE BOLTS TORQUED CORRECTLY? I GUESS I WOULD PULL THE CASE BACK OFF AND DO A VISUAL INSPECTION OF THE GASKET, AND SEALING SURFACE. AMKE SURE BOTH SURFACES ARE CLEAN AND SMOOTH, MABYE THAT IS YOUR ISSUE. JUST SOME IDEAS... Quote
omalavet Posted June 21, 2008 Author Report Posted June 21, 2008 MABYE THE SEAL HAS BEEN DEFORMED AND DOESNT SEAL CORRENTLY. AMBYE SUMTHING GOT IN THERE WHILE YOU WERE INSTALLING IT AND NOW IT IS LEAKING? ARE THE BOLTS TORQUED CORRECTLY?I GUESS I WOULD PULL THE CASE BACK OFF AND DO A VISUAL INSPECTION OF THE GASKET, AND SEALING SURFACE. AMKE SURE BOTH SURFACES ARE CLEAN AND SMOOTH, MABYE THAT IS YOUR ISSUE. JUST SOME IDEAS... thanks i just bought a ew seal and install it and no leak at all for now..... hope that solve the problem in the long term.... Quote
