kwickez Posted June 11, 2008 Report Posted June 11, 2008 someone put different bolts on the rear end when i got it (bolts with tons of washers) and i need to know if 3 parts need regular bolts or grease bolts 1)top shock bolt 2)bottom shock bolt 3)front of arm relay http://www.yamaha-motor.com/outdoor/parts/home.aspx (part number 14 on swing arm) 4)back of arm relay please help Quote
okbeast Posted June 11, 2008 Report Posted June 11, 2008 Front and back of the dogbone are, shock ones aren't. Quote
kwickez Posted June 11, 2008 Author Report Posted June 11, 2008 thanks thats what i though but he gave me a grease bolt and said it was for the shock.rocky mountain told me it was for the top of the shock and a local dealer told me it was for the bottom,i tried both(neither fit well) but i also had to change the swing arm bushing and realized that the front of the dog bone had a regular bolt,i took it out and it was greased to hell and then it hit me that maybe the grease bolt went here.but i wanted to check here to m ake sure.thanks again. Quote
