im at about sea level. i want to run pump gas mostly of the time and maybe throw in some race gas every now and then i only have bolt on as far as fmf pipes,aftermarket reeds, uni pod filters,timing plate at +4, what is the biggest i should go in mill size and still run pump gas??
Be sure and do a compression check before running pump gas with those. I had a motor with 180 psi with 20 cc domes/don't remember what psi 21s are supposed to be at sea level.
alriight can you convert .020 to cc's for me because i just orderd 21cc cool heads how will those work out?
Ya I think ur a little confused about this whole thing.
Don't wanna be an ass here but instead of starting a new thread for every question try the search, it's not the best but it does work. And if you wanna do even better use this, http://www.google.com/advanced_search?hl=en
