Rodneya Posted June 4, 2008 Report Posted June 4, 2008 I have a stock 03 banshee and am installing a FMF Fatty pipe and K&N filter with a K&N powerlid. I live in Vancouver Canada and run at sea level with 32:1 premix ratio. Ave temperature here is around 70 to 75f. FMF recommends 260 main with the needle on the 3rd clip and air screw at 1.5 turns on a machine with no other mods. K&N recommends 340 mains with needle on 5th clip and air screw at 2 turns on a machine with no other mods. What is a happy medium to get me going. Quote
moneybags Posted June 4, 2008 Report Posted June 4, 2008 I had a stock Banshee once. My first mods were a set of Toomy T-5 pipes and a K&N power lid. I ride at sea level and have the same temps as you. I was running a 320 main jet and 27.5 poilets. It was running a little fat but better safe then sorry. The instructions that come with the power lid are junk. Maby they revised them, I dont know. The instructions that came with mine said to put different size jets in each carb. :shoothead: Hope this helps you. Quote
Michael Jackson Posted June 5, 2008 Report Posted June 5, 2008 (edited) one of those k&n lids will obviously flow less air , if anything,. than no lid at all, i would start at a 280 with needle on 3rd clip and stock pilot, 280 might even be fat, ive never used one of those lids i think the people at k$n are out of their minds from the sounds of it Edited June 5, 2008 by Michael Jackson Quote
moneybags Posted June 5, 2008 Report Posted June 5, 2008 one of those k&n lids will obviously flow less air , if anything,. than no lid at all, i would start at a 280 with needle on 3rd clip and stock pilot, 280 might even be fat, ive never used one of those lidsi think the people at k$n are out of their minds from the sounds of it :shoothead: Quote
