I got a rebuild kit for my kick starter lever and I am lost on how to install. The guts were all together missing when I pulled it apart. Does any one have detailed instuctions to put the kit in (spring and ball bearing)? Any help is appreciated! Thanks Dominic
This is from a parts fiche that breaks down the kick start assembly if you have any question just ask. When I rebuilt my kickstarter it rattled a ton put a larger o-ring in (Had one lying around) and packed it with some thick grease and it works perfect slides easy and stays firm during idle.
Edited by Fearnot
Hey thanks a lot. I was lookin' at this and seem to be a pain to keep the spring and ball bearing in place while puttin back together. Any tricks?
A little grease will hold the spring and ball in place. You might have to push the spring and ball in just a tad bit to get the kick start lever to slide over them.
