kawiking Posted May 27, 2008 Report Posted May 27, 2008 what size motor uses the big flange pipes ? Quote
kawiking Posted May 27, 2008 Author Report Posted May 27, 2008 http://cgi.ebay.com/ebaymotors/ws/eBayISAP...em=300226909668 Quote
kawiking Posted July 14, 2008 Author Report Posted July 14, 2008 well.. i thought i could weld my flanges off my fmfs on to my shear pipes... i guess not, the tube is much bigger were the flanges mount on.. so i m not sure what to do with these shear bb BIG flanged pipes..... and ideal wouln be great.. i hate to sell them and buy new pipes,but its lookin that away. Quote
Wildcardracing Posted July 15, 2008 Report Posted July 15, 2008 Did you braze the original flanges back on them??? Find a machine shop to cut some for you, give them the measurements and they should be able to turn some out on a lathe pretty easy. Not necisarilly what I'd have done, but about the only way I can see accomplishing what you're trying to do. Not sure if that braze will hold up to the heat though, are you running methanol or gas??? Might be able to get away with it on meth. Hope that helps. -slo Quote
kawiking Posted July 15, 2008 Author Report Posted July 15, 2008 i bought them off a guy on e bay.... the link is acouple of post back. i can only think of one shop id let weld them on if i can get some flanges. i might sell them or try and get intough with shear and see how much it would be to have the small flanges back on/ Quote
kawiking Posted July 15, 2008 Author Report Posted July 15, 2008 took some meas closer to the flange shear cpi Quote
FireHead Posted July 15, 2008 Report Posted July 15, 2008 Did you braze the original flanges back on them??? Find a machine shop to cut some for you, give them the measurements and they should be able to turn some out on a lathe pretty easy. Not necisarilly what I'd have done, but about the only way I can see accomplishing what you're trying to do. Not sure if that braze will hold up to the heat though, are you running methanol or gas??? Might be able to get away with it on meth. Hope that helps. -slo Some folks make bushings that they put inside the BB pipe flanges so that they can run them on small flange engines. :geek: Quote
kawiking Posted July 15, 2008 Author Report Posted July 15, 2008 Some folks make bushings that they put inside the BB pipe flanges so that they can run them on small flange engines. :geek: thats is actually what i need !!!! im sure u cant buy them.... im not sure who i could get to fab them up ? Quote
FireHead Posted July 16, 2008 Report Posted July 16, 2008 thats is actually what i need !!!! im sure u cant buy them.... im not sure who i could get to fab them up ? Twister, Matt Shearer, the guy from GRR, K&T, etc. It will require a phone call or two though. Quote
kawiking Posted July 16, 2008 Author Report Posted July 16, 2008 Twister, Matt Shearer, the guy from GRR, K&T, etc. It will require a phone call or two though. Cool... Thanks for the help,boss... I ll see what I can come up with ! Does anyone now shears web site ?? Quote
