eric1981 Posted May 27, 2008 Report Posted May 27, 2008 (edited) Im having problems when i get the shee warmed up, it doesnt like to stay runnin at idle. Idle is a little low, but i cant get it to idle up i have messed with the idle screw and it seams not to change a bit. Its a 98 banshee with milled head t-5 pipes Ballanced flywheel and welded and trued crank bored 20 over with flowlite pistons. port and polished. boyseen reeds. and pwk 33's carbs. Seams to be jetted properly plugs look good and not runnin to lean mayby a little rich but beter to be a little rich then to lean. Also runnin 32-1 race fuel. Also compression is 165 on one side and 174 on the other side. Also still have the airbox with KN filter with outerware and no lid on the box Thanks Edited May 27, 2008 by eric1981 Quote
sheefreak Posted May 27, 2008 Report Posted May 27, 2008 Im having problems when i get the shee warmed up, it doesnt like to stay runnin at idle. Idle is a little low, but i cant get it to idle up i have messed with the idle screw and it seams not to change a bit. Its a 98 banshee with milled head t-5 pipes Ballanced flywheel and welded and trued crank bored 20 over with flowlite pistons. port and polished. boyseen reeds. and pwk 33's carbs. Seams to be jetted properly plugs look good and not runnin to lean mayby a little rich but beter to be a little rich then to lean. Also runnin 32-1 race fuel. Also compression is 165 on one side and 174 on the other side. Also still have the airbox with KN filter with outerware and no lid on the box Thanks Might try to open your airscrews up and see if that helps. If it idles fine when you first start it, then goes to shit once it warms, you are rich on the pilot. Quote
sandboa Posted May 27, 2008 Report Posted May 27, 2008 I am having an identical problem with my 98 shee. Mine wouldnt run without the choke on. So I took off the carbs and cleaned them well. That fixed the problem. Now it wont idle when it gets warm. Tried adjusting the idle screws with little to no change. Quote
