caddyman Posted May 17, 2008 Report Posted May 17, 2008 I am getting a used cool head from DallasGcub and the domes a pitted.....but, does it even matter? He thinks the are 20cc.....I am not even sure thats what I need, mods are...... trued welded crank Trinity internals on a stock bore V3's 30mm OKO's...on the way..... Toomy T5's the token boost bottle open air box, foam filter.... I need to do a comperssion check to see where I'm at now, and go from there?? What would you guys reccomend? Riding style.......ride it like you stole it! Dunes, and open fire type roads, not many "trails". About sea level also. Thanks guys Quote
Bansh-eman Posted May 17, 2008 Report Posted May 17, 2008 its not good practice to run pitted domes or any internals with burs, these tiny parts of metal in the combustion chamber are much more prone to becoming hot spots making your motor either diesel or detonate. Could you run them? Yes, it could just cause more issues then what its worth. Quote
caddyman Posted May 17, 2008 Author Report Posted May 17, 2008 its not good practice to run pitted domes or any internals with burs, these tiny parts of metal in the combustion chamber are much more prone to becoming hot spots making your motor either diesel or detonate. Could you run them? Yes, it could just cause more issues then what its worth. O.K. I won't even think about running them then. What size domes you think I should run?? 18 or 20?? Quote
Bansh-eman Posted May 18, 2008 Report Posted May 18, 2008 what tpye of riding? what elevation? what kinf of gas do you want to run? Quote
caddyman Posted May 18, 2008 Author Report Posted May 18, 2008 what tpye of riding? what elevation? what kinf of gas do you want to run? Dunes and "logging" type roads. I am about sea level, I would rather not have to run race gas, but I do run premium now anyway. Quote
Bansh-eman Posted May 18, 2008 Report Posted May 18, 2008 A 21cc dome should give you around 156 according to the NOSS website. I wouldn Quote
caddyman Posted May 18, 2008 Author Report Posted May 18, 2008 A 21cc dome should give you around 156 according to the NOSS website. I wouldn Quote
