monster_energy06 Posted May 17, 2008 Report Posted May 17, 2008 (edited) ok i blew my calble yesterday with tors caps.. so said fuck it and drilled and tap my carbs for idle scews and put on my once lost, found again tors delete caps on. in the process i bent a needle .. il do it tomrow i say... so today go out try i out thorttle was stickin justa bit off the top. start takin out my tops and changing needles noticed i had a lot of slack in my cable from the carb tops wtf.. meh fuck it .. start it up ran weird hit the gas rev out hi for a few secs then goes to idle sometimes also chokes it selof wen i lightly hot the gas like a bog. i worked and played on it for hours noting still sticking and it way worst then beffor.. also notice after riding, driling, and taping, theres not really much idle screw comming out for ajustmen whats up with that?? Edited May 17, 2008 by monster_energy06 Quote
rtcc Posted May 18, 2008 Report Posted May 18, 2008 I cant anwser all your question, but I know when I did my tors removal if I screwed the caps all the way down really tight the throttle would stick everytime. So now I just do it finger tight and then use the locking tabs to keep them in place. Works perfect. also, it took me awhile to get all the slack in the cable adjusted correctly. You have to have just the right amount of turns in the idle screw as well as have the cable inlet screws the exact same. It will eventually idle nice you just have to have everything in balance. Quote
monster_energy06 Posted May 19, 2008 Author Report Posted May 19, 2008 I cant anwser all your question, but I know when I did my tors removal if I screwed the caps all the way down really tight the throttle would stick everytime. So now I just do it finger tight and then use the locking tabs to keep them in place. Works perfect. also, it took me awhile to get all the slack in the cable adjusted correctly. You have to have just the right amount of turns in the idle screw as well as have the cable inlet screws the exact same. It will eventually idle nice you just have to have everything in balance. tx the response. ya i did notice it was worst with that caps being to tight that's fucked imo.... it idles fine .. but i still fine that my idle screws are to short???? .. everything was fine until i played with the cable slack on the tops.. is there supaused to have that much slak in those cables?? anyways first thing il doo is take a 1" drill bit machine down that ilde screw piece about 1/8" smooth it back level and re tap if needed.. but still have my dought on the cable Quote
wesw Posted May 19, 2008 Report Posted May 19, 2008 first learn how to type or half ass spell shit your jibberish shit is hard to understand and help you. while the slides are out take some emery paper and light scrap the bottom of the slides ive seen some stock ones with lil burrs and would snag a bit and stick. make sure the cut aways on teh slides are sticking towards the filter. then put the tops on tighten them snuggly then you need to sync the carbs up. there is avideo i did to help you do that in the video section. then adjust the free play at the throttle housing. Quote
monster_energy06 Posted May 20, 2008 Author Report Posted May 20, 2008 (edited) first learn how to type or half ass spell shit your jibberish shit is hard to understand and help you. while the slides are out take some emery paper and light scrap the bottom of the slides ive seen some stock ones with lil burrs and would snag a bit and stick. make sure the cut aways on teh slides are sticking towards the filter. then put the tops on tighten them snuggly then you need to sync the carbs up. there is avideo i did to help you do that in the video section. then adjust the free play at the throttle housing. tx for the tip bud, and would u rather have me spell everything in french???lol. cuz it would a hell of alot easier for me lol...anyways tx again ill try that Edited May 20, 2008 by monster_energy06 Quote
