I adjusted the clutch and took her out for a spin, I shifted into second and all of a sudden my clutch lever wont do anything. Did I just break the clutch or is there some easy fix involved in here. Newbie here is really confused.
Cable broke maybe? Does it move the clutch arm? Did you adjust the internals or just the perch?
I adjusted the internals and i ripped it back open and if i tighten it up it will work again, but then if i pull on the clutch lever it will snap loose again.
