1quikbanshee Posted May 13, 2008 Report Posted May 13, 2008 hey i have a 90s banshe and when its running it drips coolant from one of the bolts under the motor by the oil drain plug. what could be the problem? Quote
J-Madd Posted May 13, 2008 Report Posted May 13, 2008 It's most likely leaking around the o-ring in where the alluminum tube from the side cover goes into the case. From there it goes through the hole in the case (under the carbs there is a hole that goes all the way through) and runs down the bottom of the case, giving the appearance that it is coming from one of the case bolts. I don't think anything ever leaks from those. Quote
