PanteraCFH420 Posted May 12, 2008 Report Posted May 12, 2008 Well i just put my banshee together and its not getting any spark. Im pretty sure the wiring is good and the stator is good. What should i do? Quote
LeadBoots Posted May 12, 2008 Report Posted May 12, 2008 (edited) did ya hook the ground back up on the voltage reg? killswitch on? plug the coils back in? Did ya put the flywheel key back in the groove? Edited May 12, 2008 by LeadBoots Quote
arfountain Posted May 12, 2008 Report Posted May 12, 2008 I've got a similar problem, thankfully I have two shees and swapped the coil, and cdi and the shee still wont get spark. I am getting really pissed, I had it running, took the carbs off for a cleaning, then next thing I know, I have no spark. What gives? Any suggestions. Quote
PanteraCFH420 Posted May 12, 2008 Author Report Posted May 12, 2008 Ya, i did all that stuff but im gonna try a new cdi. Quote
1996dragshee Posted May 12, 2008 Report Posted May 12, 2008 CDIs rarely go out.if you did all the above,do the both of you have the tors shit removed with all the plugs that go with it? check your grounds and harness plugs. or if u have another wire harness,swap it out.chances are its in the harness wiring somewhere or the tors bullshit if u still have it on.good luck with it Quote
PanteraCFH420 Posted May 12, 2008 Author Report Posted May 12, 2008 (edited) How many ground are there on a '97? I got one hooked up in the back to the regulator only. and ya i still have the tors hooked up. Edited May 12, 2008 by PanteraCFH420 Quote
Snopczynski Posted May 12, 2008 Report Posted May 12, 2008 plug caps are a common problem. Pickup coil gap on a rebuild or if someone dropped the flywheel and cracked the magnets inside of it. Quote
