yama_banshee87 Posted May 11, 2008 Report Posted May 11, 2008 was wondering what i should do for the shocks on my banshee. they are not in bad shape just want to upgrade. any insight would be great. maybee yfz 450 shocks, works. thanks in advance Quote
JKJK Posted May 11, 2008 Report Posted May 11, 2008 Will.Give me a call.My bro just upgraded+has a nice pair of Works triple rate,non adjustable,remote rezzy shocks.150.00+the ride,they would be a big improvement over what you have now. Quote
yama_banshee87 Posted May 12, 2008 Author Report Posted May 12, 2008 Will.Give me a call.My bro just upgraded+has a nice pair of Works triple rate,non adjustable,remote rezzy shocks.150.00+the ride,they would be a big improvement over what you have now. cool cool john. Quote
yama_banshee87 Posted May 13, 2008 Author Report Posted May 13, 2008 that didnt go through just wondering what the best up grade would be for me thanks Quote
hylander88 Posted June 3, 2008 Report Posted June 3, 2008 I would replace the stock j-arms.....thats are next up grade on ours....and its the hard way running in 4th gear when the ball joint blew apart ..Ouch.......2 broken arms and leg.... Quote
slc_hillshooter Posted June 4, 2008 Report Posted June 4, 2008 I would replace the stock j-arms.....thats are next up grade on ours....and its the hard way running in 4th gear when the ball joint blew apart ..Ouch.......2 broken arms and leg.... A quick easy fix we used to do is find a set of banshee stock shocks 91 or newer. They do not use the taper spring, much better ride, lot less stiff and you can pick up a set for less than fifty bucks on ebay. Quote
