tundish2800 Posted May 8, 2008 Report Posted May 8, 2008 The motor will idle fine when you hit the throttle it bogs out and stalls. the motor is completly stock no pipes it still has an air box on it. good compression reeds are like new Quote
4smoke20 Posted May 9, 2008 Report Posted May 9, 2008 The motor will idle fine when you hit the throttle it bogs out and stalls. the motor is completly stock no pipes it still has an air box on it. good compression reeds are like new i had the same problem and it turned out that my vent tube on the gas cap was pinched. cut it where it was pinched and its been good ever since. check it out and maybe youll get lucky with an easy fix. Quote
