gumby6t9 Posted April 13, 2008 Report Posted April 13, 2008 Figured I would install my new rear sprocket while I'm waiting on my cylinders to get back from Flotek... Took a quick look at my manual and thought to myself "huh, those nuts didn't seem like they were torqued to 43 ft/lbs" but since the book says so I started at 20, then 30, 40, then tried to get to 43... that didn't happen. Upon further investigation I found out I was in the older section of the manual that covered the older sprocket carrier (the 4 bolt one...) the newer 6 bolt on is torqued to 17 ft/lbs. F-it. I'm done for the day! Quote
Screaming Yellow Zonker Posted April 14, 2008 Report Posted April 14, 2008 can you tap it out for a larger bolt? Or Heicoil it... Quote
okbeast Posted April 14, 2008 Report Posted April 14, 2008 Just drill those out, use a bolt/lockwasher/and nut...DONE. Quote
bada450r Posted April 14, 2008 Report Posted April 14, 2008 Just drill those out, use a bolt/lockwasher/and nut...DONE. what he said ^^^^^^^^^^^^^^^^^^^^^^^ Quote
gumby6t9 Posted April 14, 2008 Author Report Posted April 14, 2008 I got the studs out. Ordered new studs and nuts. Quote
