Hey where can you get clear radiator tubing and a glowing die to put in the coolant, hardware store tubing i don't think is good enough.
the hardware store tubing is good enough. (shit with the weave nylon inside?) but it does wear out. it will get brittle after a while as well as stain. but shit, that happens.
get some of it and use it! KEEP IN MIND that you might as well replace it every yearbecause it doesnt have the rubbery make up that normal rad hose has.
or you can go to a performance shop and buy some lengths o stainless braided rad hose. you can also get the stainless braided stuff that is coated as well.
Yea i had bought some of the nylon braided stuff but it seemed to be to flimsy and kinked real bad at low degree angles
