I think that looks perfect Tate!! I wouldn't change them! As far as the hard starting, do you still have the 25 pilots in there? I stepped mine up to the 27.5 and it cured my hard starting problem. :thumbsup:
Yeah now that I've been working on the wife's banshee I forget what size pilots I have in mine... :confused:
I'm going to pull them apart and check while I double check my float level in the next few days.
By the way, I'm not positive yet but I think me and a couple other buddies might go try to find somewhere to ride this weekend if you want to go? I'll let you know if it's going to happen and what day...
If you did the plug chop properly, as in warm it up on old plugs, put brand new ones in, went from 1 to 5 or 1-6 gear WOT then shut it off, put old ones back in and cut them...then I'd say you're 1-2 sizes rich.
That being said...if the bike revs all the way out cleanly and does not feel boggy, etc., then you can leave it.
I'd rather be a little safe rich than on the edge of lean/rich.....which, again...if the plug chop was done correctly, you're safely rich.
Yeah that's exactly how I did it. I'm still a little undecided, I think I might leave it but the majority of my riding is done 3000-4000 feet higher in elevation than I am at right now with will cause it to be a little richer so we'll see...
