endofitall9 Posted April 2, 2008 Report Posted April 2, 2008 Ok guys I'm going to go ahead and start getting everything ready for next winters build I already have the rz cylinders servos and cables. what i dont have is the electronics. I know that the banshee flywheel will work with the rz stator but they wont work vice versa.. I have also read that guys are using PVL ignitions with their RZ's. I have contacted Zeeltronics and asked him about his CDI,Igniton,and PV Contoller ,However I have yet to get a response. I'm Wanting to run all of the Banshee electrics such as stator,Flywheel, or Go the PVL route, however once again I have no hard evidence saying it will work. Just trying to get any info I can on making this swap as easy and smooth as I can using the parts that will be most available.. thanks guys! Quote
endofitall9 Posted April 2, 2008 Author Report Posted April 2, 2008 ok, well apparently if you buy the zeeltronics ppv,and cdi you can run the banshee flywheel and stator, now for my next question! How would one go about elinating the batter on the rz conversion.....using the zeeltronics electronics...? Quote
BenBB Posted April 2, 2008 Report Posted April 2, 2008 You SHOULD be able to use a battery eliminator, pretty common on ebay or at least they used to be. I've heard they are all pretty much the same between models (like RZ350, Kawi triple, whatever) with just different connectors so if an RZ350 one wasn't available you could try one for somethin' else. Good luck. Quote
endofitall9 Posted April 2, 2008 Author Report Posted April 2, 2008 Hey, thanks Benbb I've been reading all the old posts on this conversion, Does anyone have any pictures how and where they mounted the PV servo, Also Ben when you elimnate the battery you still need the RZ rectifier to run the whole stup correct? Quote
