idle screws?
dont know how the twist throttle kits work or what kind of carb caps they come with, but once you remove the tors you need to install the real idle screws and u need the throttle cable that is made for the caps without the tors, did the twist throttle work with the tors on? or were the tors already off with the twist throttle on? if the caps are the same all you need is the throttle cable and idle screw kit which is just idle screws, drill bit and tap, if you have bits and a tap that size already you can probaly just buy the screws alone
Edited by Michael Jackson
how would i know? its your bike and your askign me if it has throttle screws installed? take a pic of the carbs and i could tell you..your asking if you need idle screws?if the tors are removed, yes is your answer, but if you already have them, why are you asking if you need them?
Yes it should work on stock carbs. But you will need to make sure they have the idle screws drilled/tapped/installed to be done correctly.
Fox, if your ordering from Cascade already, they should have the idle kit too. If not give us a call :
http://www.farmandsandtoys.com/partdetail.asp?partid=123
