foxracing350 Posted April 2, 2008 Report Posted April 2, 2008 i currently have a twist throttle on my shee now and im putting a thumb throttle back on and i just ordered the cable through cascade and i need to know if i need idle screws or anything else? i should just be able to put the new cable on and the thumb throttle and ill be fine right? Quote
Michael Jackson Posted April 2, 2008 Report Posted April 2, 2008 you still got the TORS system on? Quote
Michael Jackson Posted April 2, 2008 Report Posted April 2, 2008 (edited) dont know how the twist throttle kits work or what kind of carb caps they come with, but once you remove the tors you need to install the real idle screws and u need the throttle cable that is made for the caps without the tors, did the twist throttle work with the tors on? or were the tors already off with the twist throttle on? if the caps are the same all you need is the throttle cable and idle screw kit which is just idle screws, drill bit and tap, if you have bits and a tap that size already you can probaly just buy the screws alone Edited April 2, 2008 by Michael Jackson Quote
foxracing350 Posted April 2, 2008 Author Report Posted April 2, 2008 i got it with the tors removed and the twist on it why would i need new idle screws? dont the twist throttle have idle screws? Quote
Michael Jackson Posted April 2, 2008 Report Posted April 2, 2008 how would i know? its your bike and your askign me if it has throttle screws installed? take a pic of the carbs and i could tell you..your asking if you need idle screws?if the tors are removed, yes is your answer, but if you already have them, why are you asking if you need them? Quote
foxracing350 Posted April 2, 2008 Author Report Posted April 2, 2008 i am asking because i did not know sorry for my inconvience i figured i could get some answers from the banshee know it alls Quote
FASTOYS Posted April 2, 2008 Report Posted April 2, 2008 Yes it should work on stock carbs. But you will need to make sure they have the idle screws drilled/tapped/installed to be done correctly. Quote
foxracing350 Posted April 2, 2008 Author Report Posted April 2, 2008 Yes it should work on stock carbs. But you will need to make sure they have the idle screws drilled/tapped/installed to be done correctly. Thankyou Quote
ClimbAnyHill Posted April 2, 2008 Report Posted April 2, 2008 You can order idle screws from MotionPro.Com, you can even run the carbs to a local machine shop to drill & tap for 30 bux! It's simple though, you only drill thru a small wall. The tap is easy, just make sure you backout the burs every few turns. Quote
FASTOYS Posted April 2, 2008 Report Posted April 2, 2008 Fox, if your ordering from Cascade already, they should have the idle kit too. If not give us a call : http://www.farmandsandtoys.com/partdetail.asp?partid=123 Quote
foxracing350 Posted April 2, 2008 Author Report Posted April 2, 2008 thanks guy im hoping with the twist throttle they already have them drilled and tapped in there so i can just throw the new cable on and be set im gonna check it out this weekend Quote
ClimbAnyHill Posted April 3, 2008 Report Posted April 3, 2008 The idle screws don't come with that cable setup, the idles screws go into the carbs! Quote
