rtcc Posted March 24, 2008 Report Posted March 24, 2008 ok, so I need to cut down my tie rods in order to screw my ball joints in all the way. I need them in all the way cause I need to drill them to secure them with a cotter pin. I have another thread going call ball joint safety... So what is the best way to do this? I remember a lot of talk about this on the wicked thread but it wasnt that specific. What can I use to cut it? Do I need to add any more threading? I would say a 1/4" should do it? I cant figure out any other way to do this. Thanks Quote
Bansh-eman Posted March 24, 2008 Report Posted March 24, 2008 you just need to use a metal cutting blade on a chpo saw. make sure you cut the right hand side so you can buy a normal tap to clean the threads. I was the retard that cut the left hand side and couldnt get a tap to clean it up. Quote
Michael Jackson Posted March 24, 2008 Report Posted March 24, 2008 (edited) edit* nm i see what your saying now Edited March 24, 2008 by Michael Jackson Quote
Bansh-eman Posted March 25, 2008 Report Posted March 25, 2008 u can get a tap for it.. i know.. i own one.. if u want one let me know i'll get ya the hookup its already taken care of, but its alot ezer to get a right hand tap then it is a left hand tap. Quote
FireHead Posted March 25, 2008 Report Posted March 25, 2008 ok, so I need to cut down my tie rods in order to screw my ball joints in all the way. I need them in all the way cause I need to drill them to secure them with a cotter pin. I have another thread going call ball joint safety... So what is the best way to do this? I remember a lot of talk about this on the wicked thread but it wasnt that specific. What can I use to cut it? Do I need to add any more threading? I would say a 1/4" should do it? I cant figure out any other way to do this. Thanks You need way more than .25" of thread depth........... I would go for atleat and inch. :thumbsup: Quote
rtcc Posted March 25, 2008 Author Report Posted March 25, 2008 ok got it all done!!! It wasnt that bad really. I just had to redo all the setting of the front end to have enough room to drill. Got cotterpins in all the balljoint shafts. Had to cut about a 1/4" off each tie rod end but everything worked out perfect. Got it all back together and I will give it a few runs today. Still might have to do some adjustments on the toe in and out. thanks everyone for your help! Terry Quote
