vwyamaha Posted March 22, 2008 Report Share Posted March 22, 2008 I took apart the top end on my kx 125 today to do the top end. when I got down to the piston I came to the lovely realization that theres about a quarter inch of play in the rod (side to side). It doesnt twist but side to side. Soooo my question is: Is this normal? which it probably isnt so my next question is whats the damage to my pocket. Do I need a new rod and bearing, a new crank etc. Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted March 22, 2008 Report Share Posted March 22, 2008 its normal to have play for side to side but not normal for it to be 1/4 in. how old is the motor? might be time to rebuild it. Quote Link to comment Share on other sites More sharing options...
vwyamaha Posted March 22, 2008 Author Report Share Posted March 22, 2008 its a 94, i dont no if its a quarter inch but not much less. If i ran it like this for a bit is it going to be more expensive to fix later? Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted March 22, 2008 Report Share Posted March 22, 2008 it wont be any more expensive as long as the crank doesnt let loose. you can buy a used stock crank for next to nothing. id just replace it and be safe if it has as much play as you say it does. Quote Link to comment Share on other sites More sharing options...
vwyamaha Posted March 22, 2008 Author Report Share Posted March 22, 2008 ok thanks man Quote Link to comment Share on other sites More sharing options...
