Re4peR26 Posted March 21, 2008 Report Posted March 21, 2008 Well today i went to go ride.. started my bike like normal and idles perfect i go and hit the gas it like bogs or some sort... So i take the TORS off cut all the wires E tape all the wires so no water or what not can get in there... Then checked the plugs.. looked a lil old, Replaced them. Started it up idles perfect.. but wont rev.. but yet the bike ran great like 2 days prior.. Do you think i should clean my carbs? Quote
man27 Posted March 21, 2008 Report Posted March 21, 2008 Did you unhook the black box!!!! :sad: Quote
Re4peR26 Posted March 21, 2008 Author Report Posted March 21, 2008 Did you unhook the black box!!!! :sad: Yeah I had to it wouldent even start with it plugged in. Quote
man27 Posted March 21, 2008 Report Posted March 21, 2008 Okay if it bogs at quarter to half throttle change the pilots check the plugs and you could change a clip up or down, if it's 3/4 to full change the mains . It all depends on the plugs!!!!Hope this helps.... :thumbsup: Quote
Re4peR26 Posted March 21, 2008 Author Report Posted March 21, 2008 it bogs even trying to get in the gas at all. Im not sure whats up Pilots help me out here... Quote
ohiobanshee Posted March 21, 2008 Report Posted March 21, 2008 Check the parking brake switch on the handle bars. Quote
man27 Posted March 21, 2008 Report Posted March 21, 2008 it bogs even trying to get in the gas at all. Im not sure whats up Pilots help me out here... If it's not the Ebrake switch good point Ohiobanshee!!!! :beer: Take the carbs apart make sure the pilots are not clogged if they aren't put in bigger!!!! :thumbsup: The pilot jets are the small jets beside the mains down in the carbs... :beer: Quote
Re4peR26 Posted March 21, 2008 Author Report Posted March 21, 2008 If it's not the Ebrake switch good point Ohiobanshee!!!! :beer: Take the carbs apart make sure the pilots are not clogged if they aren't put in bigger!!!! :thumbsup: The pilot jets are the small jets beside the mains down in the carbs... :beer: HAHAHA i just did the ebrake block off and thats prolly my problem!!!!!!!!! i didnt unplug the sensor!! so im going to unplug it and hopfully thats my problem!!! Quote
jmd0346 Posted March 21, 2008 Report Posted March 21, 2008 If it ran fine before dont start changing jets. I cant understand why ignorant people tell others to do that when they have problems like you have. Jetting doesnt just get off overnight. Especially so much that it causes the bike to not run. You have an electrical problem. Quote
Re4peR26 Posted March 23, 2008 Author Report Posted March 23, 2008 If it ran fine before dont start changing jets. I cant understand why ignorant people tell others to do that when they have problems like you have. Jetting doesnt just get off overnight. Especially so much that it causes the bike to not run. You have an electrical problem. The problem was my Ebrake switch by the radiator. Its fine now. I elminated the TORS and cleaned up alot of wiring while the bike was apart thanks guys! Quote
