r_flagel222 Posted March 16, 2008 Report Posted March 16, 2008 here is the scoop, raced 3 days last weekend on a complete rebuild... ran fine no problems at all, once i got it jetted right. put up on stand in garage, left sit for a week. went out there today to start and ride a little bit and fuck ! their is no tension on clutch lever... so i checked for broken cable, cable good. next step, to the clutch arm that goes into the motor... and no resistance except the sring thats suposed to be on it. next step bike was on floor in gear, tried to roll it... it has good clutch pressure, turns over motor if rolled hard enough.my guess is that it has got to be the lever that goes in the motor or the rod that goes though the motor that relieves the clutch spring pressure .... maybe the 10 mm nut, in the middle of the clutch pressure plate, that we use to adjust our clutch position came loose............ whats your guys take on this situation? thanks anyone who puts out ideas here! Quote
theshee Posted March 16, 2008 Report Posted March 16, 2008 same thing happened to me one time. Jamb nut on the adjuster in the center of the pressure place came loose... I would bet that is your problem too. I would suggest getting the cascade adjuster. it has an allen head instead of the stock phillips screw that strips out easily. Has a pancake built in too. Check it out. Quote
r_flagel222 Posted March 16, 2008 Author Report Posted March 16, 2008 same thing happened to me one time. Jamb nut on the adjuster in the center of the pressure place came loose... I would bet that is your problem too. I would suggest getting the cascade adjuster. it has an allen head instead of the stock phillips screw that strips out easily. Has a pancake built in too. Check it out. thanks bro... thats one of my things to check next as i stated. how much is that cascade adjuster? Quote
theshee Posted March 16, 2008 Report Posted March 16, 2008 thanks bro... thats one of my things to check next as i stated. how much is that cascade adjuster? I think its 45 bucks, but comes with a pancake bearing. It is the first thing I buy for my bikes now. Quote
