I need help getting the jetting right on my bike after riding awhile the cylinders and pipes have fuel on them, most mods are in sig, here's what isnt in the sig, EGN needles 48 pilots, 148 mains, around 155psi in each cylinder on fresh rebuild, elev. is around 1150 above sea level, temp is around 60 or 70 deg. im not sure of the port on the cylinders (they came on a different bike that i sold), i think its a dune port. Could it be bad reeds, wronge needles, or just rich, or could the cases be leaking, i just split them to put new seals in, it done this before i split them too, or is it just to much carb?
should i be running a CEL needle, its acts like its running rich
