ramboner69 Posted March 12, 2008 Report Posted March 12, 2008 are chokeless carbs a big PIA? or will it be ok with warmer weather? any help Quote
2001Stroker Posted March 12, 2008 Report Posted March 12, 2008 (edited) I have Keihin 35mm carbs. They still have the chokes on them. The weather around here sucks. One day it's 79, and the next it's 30. Temps range anywhere from 10 degrees and no humidity in the winter, to 110 degrees and 100 percent humidity in the summer. I have never used the chokes. My bike starts on the 2nd kick, no matter how cold it is. But, I'm sure it all depends on how cold blooded your engine is. I use race gas, with alot of compression. That may have something to do with it. I'm sure your luck is just like mine, though. If you buy them without chokes, you'll need them. Edited March 12, 2008 by 2001Stroker Quote
