ramboner69 Posted March 10, 2008 Report Posted March 10, 2008 im debating if im gonna need a lock up first off im not too familiar with a lock up and or what it exactly does also im not sure if they make just a lock up or if you the need the cover also ill be running a 5mm stroker with a vitos mono block with 69.95mm pistons shearer bb inframes mikuni 34mm carbs any help would be great as im new to building a non bolt on motor Quote
lowbuckracing Posted March 10, 2008 Report Posted March 10, 2008 im debating if im gonna need a lock upfirst off im not too familiar with a lock up and or what it exactly does also im not sure if they make just a lock up or if you the need the cover also ill be running a 5mm stroker with a vitos mono block with 69.95mm pistons shearer bb inframes mikuni 34mm carbs any help would be great as im new to building a non bolt on motor If your draggin ,I would...That motor is gonna smoke a stocker or hd with springs,F.A.S.T racing has a solution for you just ask...Lowbuckracing... Quote
ramboner69 Posted March 10, 2008 Author Report Posted March 10, 2008 If your draggin ,I would...That motor is gonna smoke a stocker or hd with springs,F.A.S.T racing has a solution for you just ask...Lowbuckracing... i heard jeff has a kit for like $100 that solves the issue without having to go to a lock up...i dont drag a whole lot...and if i drag its down the strip maybe 4 runs a month Quote
