I see people stand up quads all the time in the back of trucks/trailers.
How safe is this for the bikes?
Is there anything to worry about or look out for?
Also, Storage.. Would it be a bad idea to store my bike standing up on the rear grab bar?
Edited by keepinITshee
[/quote
I dont see where it would hurt anything. As long as the fuel is off. LOL How long are you planning on storing it?
Yeah make sure the carbs are all dry. I stood mine up and some ran out the carbs and through my K&N. So I have goopy red oil and gas in the airbox, then I had to clean and re-oil the filter. Would have saved some time to just run it out of gas!
drain your carbs, NP.
Ill say it the 12th time too. shut off the gas. ALSO not mentioned, if like myself you dont use a rear case vent line, your oil may leak out of that too.
forgot about the vent line, if you got one it will be directly under your rear engine mount. (plastic piece with a hose) iif that aint there, theres a hole you may wanna plug up if your worried about oil drippin
