brooklyn Posted February 26, 2008 Report Posted February 26, 2008 im trying to ditch the thumb throttle and i was wondering if they made a kit i have a single carb conversion and right now my thumb throttle is all rigged up its fine but i want a twisty any info would be great Quote
Wildcardracing Posted February 27, 2008 Report Posted February 27, 2008 I haven't heard of any kits, you should be able to buy the throttle tube and housing then source a cable assembly from a motorcycle to hook it up. Shouldn't be too hard. Quote
spurdy Posted February 27, 2008 Report Posted February 27, 2008 im trying to ditch the thumb throttle and i was wondering if they made a kit i have a single carb conversion and right now my thumb throttle is all rigged up its fine but i want a twisty any info would be great If your already set up with the carb you just need to swap the thumb throttle to a twist throttle tube which comes with the appropriate housing just like a motorcycle. The only difference between what you have and a dual carb set up with a twist is the cable. Dual carb = dual cable // single carb = single cable. Thumb throttle or twist throttle just pulls the cable. Piece of cake. SP Quote
Snopczynski Posted February 27, 2008 Report Posted February 27, 2008 call cascade, they know what you need. Quote
shovelhead Posted February 27, 2008 Report Posted February 27, 2008 I beleive Trinity Racing has the Twist throttle cables for single carb.. Quote
