JUST REBULID THE TOPEND ON MY BANSHEE, BUT ONE SIDE STILL DOES'T FIRE RIGHT,THE K@N FLITER GET ALL WET WITH GAS, AND SHOOTS GAS THREW CARB. BIKE HAS VFORCE REEDS. BUT A DIFFERNT CARB ON IT AND DOES THE SAME. WHAT COULD BE WRONG.
Did you check the float level? Is the needle and seat in good conditon? Are the carbs in synch? Did you check for air leaks. Did you inspect the reeds when you had them out?
