T-daddy Posted February 23, 2008 Report Posted February 23, 2008 how do u no if the carb slide are swapt from left to right (in the wrong carb but the half moon shape facing filter) what are the symptoms :geek: Quote
Snopczynski Posted February 23, 2008 Report Posted February 23, 2008 Slide cutout does indeed need to face the filter. They develope a weird midrange burble usually. Quote
T-daddy Posted February 23, 2008 Author Report Posted February 23, 2008 Slide cutout does indeed need to face the filter. They develope a weird midrange burble usually. if there switched from left to right will it idle or no Quote
Snopczynski Posted February 23, 2008 Report Posted February 23, 2008 (edited) yeah, but the screws have to be turned in a long ways I believe. (On a tors eliminator kit). Is your choke crossover tube on? Edited February 23, 2008 by Snopczynski Quote
T-daddy Posted February 23, 2008 Author Report Posted February 23, 2008 yeah, but the screws have to be turned in a long ways I believe. (On a tors eliminator kit). Is your choke crossover tube on? yeah cross over tube on cant seem to figure out why it isnt idleing and i have the tors kit on the way should have it by tuesday i hope it helps Quote
gentner8 Posted February 23, 2008 Report Posted February 23, 2008 If its been awhile since you have cleaned the carbs, your pilots could be gummed up. Since you are going to be putting the TORS kit on, might as well do a full blown clean on them. Good luck! Quote
T-daddy Posted February 23, 2008 Author Report Posted February 23, 2008 If its been awhile since you have cleaned the carbs, your pilots could be gummed up. Since you are going to be putting the TORS kit on, might as well do a full blown clean on them. Good luck! yea i will clean them to god nose the last time they were cleaned they need to be cleaned i noticed the floats are getting stuck open today it was dumpingas out of the tube ill repost on tuesday and let u guys no wats goin on Quote
TexasBansheeMan Posted February 23, 2008 Report Posted February 23, 2008 (edited) TORS IS CRAP!!!! Get a teather and cut the tors off, or get a tors elem kit, or New carbs 30 mm okos are cheap and a nice power up grade! Edited February 23, 2008 by TexasBansheeMan Quote
T-daddy Posted February 23, 2008 Author Report Posted February 23, 2008 TORS IS CRAP!!!! Get a teather and cut the tors off, or get a tors elem kit, or New carbs 30 mm okos are cheap and a nice power up grade! i hear ya them ugly shits is in the way and causing problems they will be off by tuesday :cool: Quote
Snopczynski Posted February 23, 2008 Report Posted February 23, 2008 All you have to do to defeat the tors is unplug everything. Quote
T-daddy Posted February 23, 2008 Author Report Posted February 23, 2008 All you have to do to defeat the tors is unplug everything. thats wat i did but it dosent idle at all it was like this wen i got it all wires were disconnected Quote
TexasBansheeMan Posted February 23, 2008 Report Posted February 23, 2008 i hear ya them ugly shits is in the way and causing problems they will be off by tuesday :cool: Good choice cut it all out, get some new carbs and ENJOY!!! Quote
