so i'm considering getting my jugs ported for woods / trails and adding a timing plate (+4). i'm wondering when the need to have the crank trued and welded comes in? also how much will the clutch take b4 needing a serious upgrade? i already have a hinson basket but stock hub and p-plate with a tusk kit w/ hd springs.
is there a compression point where the crank comes into play or is it just one of those things that only the extremely built motors need?
other mods are typical bolt ons:
PC pipes
pro design filter - no lid
v3's
noss head / 20cc domes
stock bore with wiseco's - honed once
i'm at about 1200 ft and jetted accordingly
Your clutch will probably be just fine, depends on your riding. With the crank it's hard to say, I've heard of shees with only pipes that have slipped a crank, I would recommend the crank be welded with your mods.
