serius4play Posted January 30, 2008 Report Share Posted January 30, 2008 OK ...iv tryed sercing for this question already and cant find what i wont to know so yea dont bitch me out cuzz im a noob with stupid ass questions. OK i have some 38mm PWK carbs an im eather getting shears or CPI in frame small boar pipes. and i was wondering if the jet kit that comes with them will work in the larger carbs and have the proper fule to air mixtuer and not make my bike run like ass nod good! oo and burn a hole in my piston'S yea that...not so good eather.... soooo u think it will work or not?????????????????????? HEEEEEEEEEEEEEEELPPPPPPPPPPPPPPPPPPPPSSSSSSS!!!!! Quote Link to comment Share on other sites More sharing options...
BaNsHeeJuNkEy Posted January 30, 2008 Report Share Posted January 30, 2008 what do you have done to it and rough elevation and we coulf tell you roughly were you should be. Quote Link to comment Share on other sites More sharing options...
Dave I. Posted January 30, 2008 Report Share Posted January 30, 2008 I didnt know shearers or cpi came with a jet kit. But your jets out of your stock carbs wont work for pwk if thats what you are trying to do. Quote Link to comment Share on other sites More sharing options...
530grafix Posted January 30, 2008 Report Share Posted January 30, 2008 Yeah That, and That too! we need more info to help ya! Quote Link to comment Share on other sites More sharing options...
serius4play Posted January 31, 2008 Author Report Share Posted January 31, 2008 ok umm i have .20 overboar, ported and polished, and im runnin between sealeveal and around 750ft (home) Quote Link to comment Share on other sites More sharing options...
530grafix Posted January 31, 2008 Report Share Posted January 31, 2008 ok umm i have .20 overboar, ported and polished, and im runnin between sealeveal and around 750ft (home) Im at 60ft asl when i had a drag port on stock cylinders and stock crank and 35mm pwks i ran a 155 main and a 48 pilot. If that helps Quote Link to comment Share on other sites More sharing options...
shanYE west Posted January 31, 2008 Report Share Posted January 31, 2008 ok umm i have .20 overboar, ported and polished, and im runnin between sealeveal and around 750ft (home) Whats the temp that you'll be riding in? another key factor when Jetting. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted January 31, 2008 Report Share Posted January 31, 2008 Please list all your mods, air box/filter setup, pipes...etc. Rider Weight, elevation, temps you ride in.... Quote Link to comment Share on other sites More sharing options...
serius4play Posted February 1, 2008 Author Report Share Posted February 1, 2008 Please list all your mods, air box/filter setup, pipes...etc.Rider Weight, elevation, temps you ride in.... guna get Shears pipes, and i have no air box, special made K&N filters, i weigh 180lb, riddin in temps around 45-70degreez F.... .20 over boar, 35mm PWK carbs, dune port and polish, Quote Link to comment Share on other sites More sharing options...
serius4play Posted February 1, 2008 Author Report Share Posted February 1, 2008 guna get Shears pipes, and i have no air box, special made K&N filters, i weigh 180lb, riddin in temps around 45-70degreez F.... .20 over boar, 35mm PWK carbs, dune port and polish, oo and i have a aftermarket crank but its still the same stroke (dont think it matters but id tell ya anyway) Quote Link to comment Share on other sites More sharing options...
BaNsHeeJuNkEy Posted February 1, 2008 Report Share Posted February 1, 2008 ok i say start with 48 or 50 pilots and air screw 1 1/2-2 tunrs out. 155 or 158 mains to start. don't know what needle you have but put it at 3rd clip. also post what needles you are using. also if u have never jeted before look in the jetting and exhaust section at the top and read the jetting topics on how to they will help you a lot they helped me a lot. along with a bunch of help from soem ppl on here. if any one has info on what i put they will let you know. but only tune one cricit at a time to make it easy get it to ideal frist. and good luck. Quote Link to comment Share on other sites More sharing options...
