banshee mulisha Posted January 28, 2008 Report Posted January 28, 2008 Ok im gonna try to describe what i have the best i can. You guys helped me out before and i need a good starting point. OK here it goes, 98 bored.020 over with a woods port from hi-tech horsepower(highly recommend),wiseco prolite pistons,cool head with 19cc domes, ngkbr8ev plugs,stock timing,v-force 3 reeds,39mm pwk carb, um aluminum open air box w/ k&n 250r filter,DMC 916 pipes and silencers,300ft above sea level and i run golden spectro 32:1 Quote
Snopczynski Posted January 28, 2008 Report Posted January 28, 2008 Ok im gonna try to describe what i have the best i can. You guys helped me out before and i need a good starting point. OK here it goes, 98 bored.020 over with a woods port from hi-tech horsepower(highly recommend),wiseco prolite pistons,cool head with 19cc domes, ngkbr8ev plugs,stock timing,v-force 3 reeds,39mm pwk carb, um aluminum open air box w/ k&n 250r filter,DMC 916 pipes and silencers,300ft above sea level and i run golden spectro 32:1 Try an eej needle middle clip, 185 main jet, 50 pilot jet, air screw 1.5 turns out. Adjust from there. You may also want to get an eek needle and try it out. Quote
