shovelhead Posted January 21, 2008 Report Posted January 21, 2008 Guys I must be a Dumb @ss. I took the exhaust , Carbs, & fenders off 3 weeks ago, and just got time to get around to re-installing everything today ..I ended up with a Spring left over? I remember taking it off, but where from?? It is long spring apprx 10"-12" long. I thought I laid everything out together( I had them with my 4 exh. springs? ) can someone help an old man? If needed I can get a pic of it.. Quote
NitroTate Posted January 21, 2008 Report Posted January 21, 2008 Guys I must be a Dumb @ss. I took the exhaust , Carbs, & fenders off 3 weeks ago, and just got time to get around to re-installing everything today ..I ended up with a Spring left over? I remember taking it off, but where from?? It is long spring apprx 10"-12" long. I thought I laid everything out together( I had them with my 4 exh. springs? ) can someone help an old man? If needed I can get a pic of it.. post a pic Quote
NYUK Posted January 21, 2008 Report Posted January 21, 2008 it is the spring that holds the stock pipes together. running stock pipes right? Quote
Dave I. Posted January 21, 2008 Report Posted January 21, 2008 did you take the water lines off? might be the rad hose that goes to your clutch cover to the water pump. thats the only spring i can think of that is that long Quote
shovelhead Posted January 21, 2008 Author Report Posted January 21, 2008 it is the spring that holds the stock pipes together. running stock pipes right? I took off stock pipes, & put Toomey's This would make since ...No spring needed for new pipes? I thought I was loosing my mind.. Quote
