bansheeyfz Posted January 20, 2008 Report Posted January 20, 2008 does anybody know how to do this. i want to p.c them so i need to take the bearing out. Quote
NYUK Posted January 20, 2008 Report Posted January 20, 2008 you need an inside bearing puller. if you don`t have one. get a long punch or screwdriver. you can cock the inner sleeve sideways inside the hub a little. and knock them out.remove the seals 1st. Quote
bansheeyfz Posted January 20, 2008 Author Report Posted January 20, 2008 you need an inside bearing puller. if you don`t have one. get a long punch or screwdriver. you can cock the inner sleeve sideways inside the hub a little. and knock them out.remove the seals 1st. coudl i reuse the old bearings. there from an 06? Quote
NYUK Posted January 20, 2008 Report Posted January 20, 2008 you could. but i wouldn`t. the pivotworks kits are cheap. and bearings are all over ebay cheap. get them whilst your hubs are at the finisher.the pinchpenny route isn`t always best. Quote
