kawiking Posted December 26, 2007 Report Posted December 26, 2007 do they make a drag axle to fit in a stock carrier ? Quote
theshee Posted December 26, 2007 Report Posted December 26, 2007 nope... I believe they are all 40mm carriers. Quote
kawiking Posted December 27, 2007 Author Report Posted December 27, 2007 well crap !! i want a drag axle ,but i have a +6 swing arm for the stock carrier. im not about to buy another swingarm and carrier to be able to run a drag axle. that sucks !!!! well i guess i'll keep turning my rims in instead. thanks shee for the heads up. Quote
shanYE west Posted December 27, 2007 Report Posted December 27, 2007 you might beable to use the stock carrier. But you would have to change the bearings to 40mm bearings. I know JJ&A sells bearing kits.. might want to give them a call and check on it. Quote
KaosBanshee44 Posted December 27, 2007 Report Posted December 27, 2007 They don't make em' i had the same problem so just said screw it i'm gonna set it up with stock for now. Quote
Snopczynski Posted December 27, 2007 Report Posted December 27, 2007 hack off the stock carrier and weld on a round housing carrier. JJ and A racing link. Quote
bada450r Posted December 27, 2007 Report Posted December 27, 2007 you might beable to use the stock carrier. But you would have to change the bearings to 40mm bearings. I know JJ&A sells bearing kits.. might want to give them a call and check on it. ^^^^^^^^^^ yea that Quote
shanYE west Posted December 27, 2007 Report Posted December 27, 2007 (edited) I changed out the 35mm bearings for 40's rather then buy a new carrier. I'm not sure if the OD of the bearings are different from a round carrier to a stock though.. You will need a new crush tube for sure if its possible. Edited December 27, 2007 by Fouledout421 Quote
