well I figuerd email me with questions would be a good start. Located in NewHampshire. Heres a short list. Cosmetic is obvious.
Paul Turner National Motor Cryo treated crank/jugs Ported bored .20 By Lauren Duncan Yes has an equalizer set up manifold with Pyramid reed cages and 34 pjs. Domes are 18 cc. flywheel is shaved shift star mod as well. Crank tured new bearings lower end (just cause we were in there) K and N airbox set up with spare. Steel braided lines swing arm Honda style carrier - 1/2 inch a-arms plus 2- 1 forward . Steer stem is plus 2. Clutch side has Billet water pump cover and uses Duncan Quick change cover, LS uses Cascade case saver with easy access to flywheel.
Shocks front and back are custon Axis 185 lbs Expert. I have new seat cover for it has Blue flames. I will have installed Hinson basket Duncan Clutch Easy pull perch. Wheel bearings I used the Honda ones from CAL ATV the have seals where I dont remember seeing them on stock yamahas. Axle is RPM dominator +4. wheels on front OMF spare rears also OMF with rings inside and out. Rear Beadlocks. Rear brake blocked off (parking) Prodesign Kill switch. Rear skid is OMF, belly I forgot I think AC. I have new rear brakes and aarm sleave and Shock bushings. I have a set of Ice tires with rear OMF ring wheels on bandits are new like just seen ice once. Ice tracks are boring. bars are quad racer bend. I tried As for ignition timing due to how it was ported I returned to stock setting. ran better at stock setting. Duncan racing told me that ahead of time but I didnt listen. . Biggest part of this banshee is literally it hasnt been beaten by an idiot and has extremly low hrs. I dont care if some banshees with 5000 hrs are worth $1,000 what ever this one was my show piece. I would like to sell this to a good person................. Nah j/k money talks lol.... I do not want to part it out.(I will if I have to) it is a truely fun perfect build in my mind well balanced for all around fun.
I will accept Paypal for a small fee so you could possibly put this on your dads credit card. $4,000 or BRO No dreamers no Trades please. Dont need Bikes boats or other shit I have all that I want. call me or email 603-878-0426 call after 1600 hrs eastern (4 pm) Email me at [email protected]
pic of Engine build day one. Can easily look like that again with a polish.
the Satan iside was me just being funny he he
Edited by BansheeBri
  • 2 weeks later...
