anyone know the port timming on a cub kit or vito sleave thanks..
I know what the as cast timing is for a stock stroke cub. Any of the other stroke cylinders will be different. Why do you want to know? :ermm:
im building chambers for my banshee motor powered 125 motorcycle..and the post timing on the barrels is a significant factor..barrels to be used will be cub and vito sleaved barrel..
Ok, so what is the original stroke of the cylinder block you are going to use?w It seems a bit odd to be making expansion chambers for cylinders that you don't have yet? :confused:
