Does anyone on here turn their rims around so that the make their stance wider? Someone told me that if I reversed my rims I could get a wider stance. Is this practical?
yup, i dont do it, but its just like getting offset wheels. Should make you a little wider.
break the bead on your front tires,
take your tires off the rims,
removed your valve stem and reverse it, inside out.
get new valve stems, drill your new hole and install your tires.
BAM your done. i ran flipped rims on my blaster and it worked awesome! :biggrin:
Might wanna put a little plummers putty in the cap before you put it on the stem. Crazy shit happens when your haulin ass
