thanks for the heads up......another question-----if a brand new hot rods crank gets welded, will you be able to ever rebuild it????
Yes you can.
Beware the 4mm cranks w/only "out of the box welding" as we have had some issues with them. We RE-weld them for better penetration!
I found out the crank I am looking at has 2-3 hours ride time on it, came off a motor with stock cylinders and a spacer plate. He did say it is missing one of the o-rings on one inside bearing. Do these matter or need to be there? He is asking 275 shipped on it, I will try and get a pic up of it.
