i have a set of maier plastic that was custom painted .... i didnt like the paint job and it started to crack, so i took some air plane stripper to it and it just wont get it all of. 2-3 coats of paint then primer underneith. can u media blast plastic/sand blast. ive got 2 1/2 sets of plastic im going to try and sell and buy a fullbore front piece..... but i got to get this damn paint off.
did you paint that craptor with blue flames in rippens vids ??
Yup...
We are a little backed up with paint projects right now due to the cold weather here, but when we get some projects out of the way we'd be happy to do it for him. When you are ready to get something done PM me or write me on myspace.
this stuff called talstrip. its blue goopy stuff.
paint er on, let er bubble, then take steel wool to it. use gooood gloves. rubber ones.
i use it at work on old propane tanks. lifts everything but powdercoat.
  • 3 weeks later...
this is as far as i got !!! 4 cans of air plane stripper and "some sanding"....
i think the hoods stock shee plastic... but im thinking the nose is maier.... who else makes fenders that roll downward like these ??
what kind of aircfaft is it you are using? I had some that sucked, it was blue gel like stuff. You need the yellow snot kind, it will take that off very quickly.
who ever painted this plastic put some damn paint on !!! it was maroon with flacks in it with white flames on it. it just had alot of stress cracks in it. i thought about trying to sand blast the damn thing !!!
  • 4 weeks later...
Go to the local autobody paint store and get the aircraft stripper in a can. Spray them down and leave them for 30 min. or so (in the shade). Go back and scrape er down. If it doesnt take it all off, do it again.
One of the best working most convenient strippers I've found is the NAKED KIND! LOL just kidding, go to Home Depot in the paint department and get the KleenStrip sprayable liquid. Make sure to use heavy duty gloves and definitely make sure to use it in warm conditions like at least around 70 deg. If you use it in cold conditions it won't do shit and you'll waste it.
It is neutralized with water but use warm water and when you rinse it the fumes are pretty harsh too so be careful.
Use a scraper or one of those gold or silver pot scrubbers from the grocery store.
That should take it off for you real well.
I used this kind of stripper to clean paint/varnish off a China Cabinet...
It worked fine, but it pales in comparison to the good aircraft stripper Keil is talking about...
That stuff will burn the hairs out of your nose....
That is a LOT of paint on those plastics....sheesh!!!
True yeah, it's just sometimes more convenient to find and it's about $23. for a gallon... But yeah you will need to probably hit it a few times no matter what...
