Does anybody have one on their shee and if so how do you like it. I'm interested in getting one but would like to hear some feedback. Im also curious if it comes with all the sensors needed or if some of them are extra (temp, rpm ). Hopefully there not junk cause i wouldn't mind having a temp gauge, rpm, speedometer all in one. Any replies welcome
I have one, it is pretty good. I like the temperature gauge and idiot lights. You can program what temp you want the warning and the over temp light to flash at you. Besides temperature, i use the distance feature the most. Honestly, I cant look at the tach when riding, and rarely look at the speedo. It comes with everything you need to hook up and make it work. I installed a small battery where the stock tool kit once was to power the idiot and back lighting. According to trail tech, you can hook it in to the banshees stock power system, but when i do it, the tach freaks out. It works better hooked to my battery, but is not perfect. I dont know if my shee has a really dirty electrical system or what, but the tach seems to jump around a lot. I was goinjg to call trail tech about it, but after riding with it some, i realized i dont really care about the tach anyway. I wind it till she sounds like shes gonna blow then i shift. LOL I could care less what the tach says.
What type of batterie are you using. Do you take it out and recharge? . I noticed on the website it says that the lights won't work unless hooked to a 12 volt system. so a small battery sounds like a good idea.
I bought one about 1 month ago. I think there great. It does come with all the sensors you need. You had a question about the battery, just use a 9volt battery and wire tie it to the frame somewhere. The trail tech tech support guy gave me that idea. You might want to invest in a better aluminum holder, it only comes with a cheap plastic holder. I believe you can't go wrong with buying one.
