2strokepat Posted November 13, 2007 Report Posted November 13, 2007 I have a 2-1 setup with fmf pipes boysen reeds and a 35mm carb and a pod filter. were should I be with jetting at 500ft.thanks for some help. Quote
2strokepat Posted November 13, 2007 Author Report Posted November 13, 2007 Which fmf pipes? FmF fatty with power core 2 and I didnt mention but there is a 47 for a piolit jet. It seems to bog at 3/4 the needle is in the first clip. it seems to never reach the power band. Quote
letsgetthisdone Posted November 13, 2007 Report Posted November 13, 2007 use an EEK needle and a 182 main, do a plug chop and get back to us.. Quote
Snopczynski Posted November 13, 2007 Report Posted November 13, 2007 What needle do you have in it? What clip position is it in? Quote
2strokepat Posted November 14, 2007 Author Report Posted November 14, 2007 use an EEK needle and a 182 main, do a plug chop and get back to us.. I moved the clip on the needle to the 3 position and most of the bog is gone now the bog is at like the 1/4 throtle spot. it also has a 195 main jet in it. the needle that is in it says "ceg on it. were can I buy that needle you said to buy. the other question is the air screw is all the way in does that meen I need a smaller pilot jet it has a 47 in it. Quote
Snopczynski Posted November 14, 2007 Report Posted November 14, 2007 (edited) I moved the clip on the needle to the 3 position and most of the bog is gone now the bog is at like the 1/4 throtle spot. it also has a 195 main jet in it. the needle that is in it says "ceg on it. were can I buy that needle you said to buy. the other question is the air screw is all the way in does that meen I need a smaller pilot jet it has a 47 in it. That needle is for a twin carb setup. you need at least an eek or an eej to start with. Sudco, cascade, carb parts wherehouse, and ironically pats small engine all sell the needles. Edited November 14, 2007 by Snopczynski Quote
