use an EEK needle and a 182 main, do a plug chop and get back to us..
I moved the clip on the needle to the 3 position and most of the bog is gone now the bog is at like the 1/4 throtle spot. it also has a 195 main jet in it. the needle that is in it says "ceg on it. were can I buy that needle you said to buy. the other question is the air screw is all the way in does that meen I need a smaller pilot jet it has a 47 in it.
That needle is for a twin carb setup. you need at least an eek or an eej to start with. Sudco, cascade, carb parts wherehouse, and ironically pats small engine all sell the needles.
Edited by Snopczynski
