robh55 Posted November 11, 2007 Report Posted November 11, 2007 Wut all needs 2 be done 2 a stock banshee engine to put NOS on it?? Quote
shee rips Posted November 11, 2007 Report Posted November 11, 2007 there are easier ways to get more power from a stock banshee. one good way is some aftermarket pipes..... Quote
blowit Posted November 11, 2007 Report Posted November 11, 2007 assuming you have all the typical power adders like pipes carbs and all that, You will want low compression around 7:1 works good in banshees. weld the crank for damn sure, use an OEM head with a gasket and NOT a cool head, start with -2 degree timing, engine needs to be fresh. Brandon Quote
robh55 Posted November 11, 2007 Author Report Posted November 11, 2007 assuming you have all the typical power adders like pipes carbs and all that, You will want low compression around 7:1 works good in banshees. weld the crank for damn sure, use an OEM head with a gasket and NOT a cool head, start with -2 degree timing, engine needs to be fresh. Brandon thanks.. Quote
